Tekno RC ET410 Thread >
Like Tree464Likes
    Hide Wikipost
Old 03-02-2020, 09:56 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Tekno RC ET410 Thread
Last edit by: rustyus
Welcome to the ET410 Wiki page.
  • 95% parts compatibility with the EB410 4WD 1/10th scale buggy.
  • Updated 3mm 7075 CNC chassis and revised A and B hinge pin braces.
  • 13mm hard anodized threaded shocks with locking spring perches.
  • New 32 pitch spur gear for ultimate durability
  • 3.5mm shock shafts with revised dual guide x-ring cartridge.
  • 7075 CNC machined adjustable hinge pin brace system.
  • Three high volume fluid-filled adjustable differentials.
  • Lightweight 7075 tapered center driveshafts.
  • Quick access to differentials and maintenance friendly layout.
  • Captured CVA front and rear driveshafts with heavy duty 6mm stub axles.
  • Fully ball raced reverse bellcrank steering system.
  • Uses 1/10th AE Offset Stadium Truck or Traxxas Slash Short Course offset wheels.
For you guys all discussing what power plant to run, I would take note of the following statement from Matt W.
Matt - Probably would recommend a 10.5 for something similar to 13.5 in a buggy. I personally run a 6.5 in it and it’s pretty fast. Pro4 4600 will run in it but it has a lot of power and will need to be turned down in the esc.
Parts Needed to convert from EB410 to ET410
Pin Replacement Tool options
Inner Hinge Pin Inserts- Degrees of Adjustment
Upgrades:
Print Wikipost
Old 06-11-2018, 07:39 PM
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
Default Tekno RC ET410 Thread
Matthew_Armeni is offline
Old 06-11-2018, 07:49 PM
wrightcs77's Avatar
Trader Rating: 551 (100%+)
Should be interesting
wrightcs77 is offline
Old 06-11-2018, 08:10 PM
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
+1 . looking forwarding to this.
Cain is offline
Old 06-11-2018, 09:20 PM
RazorRC's Avatar
Does it come with plastic shock caps?
J/k, looking forward to seeing and hearing more.
RazorRC is offline
Old 06-12-2018, 12:33 AM
Yes. That's all I can say.
aspiringracer is offline
Old 06-12-2018, 10:37 AM
AJH387's Avatar
I'm sold.
AJH387 is offline
Old 06-12-2018, 10:55 AM
So 4wd, 1/10 truggy? Will it be based on the EB410 or the SCT410?
Could be very interesting...
LOL, now I see the other thread. Rick Roll here often? :P
AJH387 likes this.
JerryRigged is offline
Old 06-12-2018, 11:15 AM
AJH387's Avatar
I assume just a EB410 with some longer arms, truggy body / wheels, right? It's hard to really picture since there isn't much on the market like this but I just am assuming similarities like the EB48 and ET48. Either way, I just want another truck, but smaller than my TLR 8ight, so this will likely be something that I would enjoy.
AJH387 is offline
Old 06-12-2018, 11:42 AM
sea1swk's Avatar
Wonder if it can be adapted to be a lighter, indoor 4x4 Shortcourse? Love my sct410.3, but it is a tank.
sea1swk is offline
Old 06-12-2018, 01:05 PM
Tech Legend
Cain's Avatar
Based on some of the parts compatibilities being shown on Tekno site, I am thinking eb410 based. Which would make for a nice platform to turn into a 2wd where you need it, like the eb210 conversion for the 410.
AJH387 likes this.
Cain is offline
Old 06-12-2018, 01:41 PM
Interesting idea. Keep the current SCT410.3 for the folks running big outdoor 1/8 tracks, and the have a SCT410SL based on a stretched EB/ET410 for smaller indoor tracks?
Rufus2010 and AJH387 like this.
Old 06-12-2018, 06:04 PM
Trader Rating: 35 (97%+)
I havn't even seen it but I am pretty sure I want one!
Tbuggy is offline
Old 06-12-2018, 06:14 PM
rvrslt1's Avatar
Trader Rating: 35 (100%+)
Has anyone see one? What class will it run in or is it for bashing? Wish they would make a true 2wd eb210 before a truck for a class that does not exist . My .02
Dont take that wrong. Sure I will still have to have one.
rvrslt1 is offline
Old 06-12-2018, 06:31 PM
rustyus's Avatar
I see someone came to their senses, and finally started the thread. There is no turning back now Tekno. You guys have to make it. I want one purely for backyard track bashing.
I can see it now. For me, it'll be Panther Step Pins on all four corners...let there be dirt.
rustyus is offline
Old 06-12-2018, 11:13 PM
RCSteveH's Avatar
I want one
RCSteveH is offline
